moss
Local PARTS for sale
SAFC Neo - $370
Apexi EL2 Vaccum Gauge - $40
* Bump Bump *
For sale:
s13 rear strut top brace, painted black $25
Stock s13 springs set of 4 FREE
Yellow Jacket coil packs S13 SR20det 1992 brand new (paid $380), for sale $300 (I thought I had a spark problem, I don't)
S13 stock front swaybar and links FREE
S13 silvia under hood heat mat and clips good condition FREE
S13 silvia under hood above headlight rubber seal FREE
S13 front bar REO cut out for front mount FREE
180sx tail lights L & R $25ea.
S13 sr20 non hicas JUST REBUILT power steering pump (unused since rebuild) $250
S13 ECU plastic cover $20
S13 manual GB mount $20
S13 silvia front bar slight damage $5
S13 silvia rear bar good condition $20
and a bit more just ask.
Do u still have the set of 4 springs???
* Bump Bump *
For sale:
And do u still have the tail lights???
Hey guys im selling my forged motor internals as i am now building a stroker motor.
Manley H beam rods
Mahle 87mm pistons
Stock SR crank
All good for 600+hp and all balanced.
Contact Troy on 0403 131 921
$1200 ono
Also have brand new
Tomei solid head conversion
Solid lifters
Rocker arms
Rocker stoppers
Supertech dual valve springs, retainers
1mm oversized valves.
All purchased in Feb this year and still in boxes.
Now also doing a VE head conversion.
Edited by YLD500
* Bump Bump *
For sale:
Sorry all the parts aren’t available anymore.
ok guys
I need to sell my sr20det head to make way for the P12 VE
The Sr20 head was fully serviced last year and i have just purchased all new gear to fit it out but no longer going that way.
Kit includes
Sr20det head fully serviced
tomei solid lifters
tomei rocker stoppers
tomei rocker arms
supertech dual valve springs and retainers
supertech oversized valves +1mm
supertech valve stem seals
supertech valve guides
This kit was going to support 700rwhp so is perfect if looking into a new head on your daily or drift car.
$2250 for the lot.
Edited by YLD500
Parts are pickup in Woden, Will swappy swappy for bride seats.
Set of 4 JDM Volks Ultra C Trispokes. 5x100 in 17x8 +34 and 17x9 +38. All rims have a bit of gutter scrape. $490.
HKS Radiator and Oil cap, suit Subaru. $60
JDM lucky stars, 17x7 +35 in 5x100. With Federal 595 tyres, very rare and hard to find, Brand new never been on a car, only a pair. $400.
Genuine R40 Kics Neo Chrome (Burnt Titanium!) Wheel nuts in M12x1.25. Full set of them, was going to put them onto my Subaru but never got around to it. $150.
Stock Subaru SVX 16x7s, 5x114.3. Have 225/50 Nexen tyres. $100
Is all that stuff installed on the head?
no its not installed in the head as i only just purchased the parts.
If your interested make me an offer.
Edited by YLD500
Hey guys
i have a bunch of 4ft fluro lights to sell. All in perfect working order, with plugs and leads for easy install.
$20 each. pick up from Farrer
Please call or sms if you would like any as i dont check NS as much as id like to these days.
0410 529 460
Edited by chosen1
Hey mate, I'd be interested in some work lights, what's you number (maybe someone else can PM me it)?
Message me his number Eiji (unless you plan on taking them all yourself, I'd probably want 2 or 3).
yeah, my number would have helped LOL
0410 529 460
Hi everyone, I blew up my SR20 at Matsuri, I'm swapping to an RB so I'm considering parting out the SR. Rough prices for stuff below, it’s a redtop, complete motor at the moment, not sure what broke but it was a big rattle so would assume a chain issue or bottom end.
  • CAS $150
  • Ignitor $150
  • SR20 AFM $100
  • Redtop Manual Turbo ECU $150
  • Redtop Manual Turbo ECU with Nistune board fitted (standard map installed) $300
  • Greddy PRO Cams, 256/272 11.5mm lift, done maybe 2000kms $200
  • Trust / Greddy valve springs, no longer available, good for high RPM, suit stock retainers $200
  • Aftermarket low mount 2 bolt externally gated steampipe manifold, suits T2 2000kms old $500
  • Aftermarket low mount v band externally gated stainless manifold, has some leaks, heat wrapped $150
  • KLS GT2871RS, 2000kms old, $400 or $500 with oil feed and water lines.
  • Inbay intercooler piping, inlet and exhaust sides, no leaks, good for responsive setup, to suit 600x300 cooler, $250 with clamps and hoses.
  • 3” intake pipe, suit low mounted GT2860/71 or possibly others, comes with hoses to connect to SR20 AFM, $100
  • GKTech RAS, $30
  • S15 injectors in 13 rail (480cc), $150
  • SR20 Exhaust manifold and T2 Turbo Gasket, $50 for the pair
  • SR20 Genuine Nissan Water Pump, was in car for 1 week, $50
  • SR20 Gearbox, whiny in first but doesn’t crunch into gears, shifter is sloppy (needs the plastic insert at the bottom) and comes with GKTech spring kit $350
  • Powder coated “Claret Red” Rocker Cover and Black Coil pack cover, Taarks chrome nuts $150
Other Things available
  • Starter Motor
  • Sandwich plate
  • Flywheel
  • Inlet Manifold
  • Engine Loom
  • Head/Block (not sure of damage yet will update when I know)
  • CA Pignose Bar/Lip combo $300
  • SR20 Front Passenger seat $20
  • CA18 Drivers Seat no rips but has a stain, $20
All parts located Southside ACT; I’ll upload some pics over the next couple of days. All prices ONO, happy to freight at buyer’s expense. Package discounts available, or buy the whole thing and put it in a Corolla or Datsun
Contact James 0404303954.
Edited by moss
Pair of 15x6.5" wheels with Pirelli tyres, barely above the wear indicator. Good condition, no gutter rash or buckles. $100
Still looking for S15 standard suspension if anyone has!?!
Please PM
In urgent need :(
Still looking for S15 standard suspension if anyone has!?! Please PM In urgent need :(
I might know someone but it might be pricey if you want to buy it. It was for rego right? So you might be able to get away with borrowing from someone else....
August Japan wheels for sale
Front: 5x114.3 17x7 +30
Rear: 5x114.3 & 4x114.3 17x8 +38
$400 for the set or $150 front / $250 rear pairs
3 tyres are bald
Thanks!
Hi all,
Trying to get rid of parts.
I've got a s15 climate control
Contact: 0401 474 668
Price: $80
I have a brand new KAAZ 2 way LSD to suit s13 silvia/180
Looking 850.. Brand new in box
0458102721
Edited by john84ie
3 tyres are bald
Thanks!
$300 if anyone is interested! They are ending on eBay tomorrow but prefer to sell local so I don't have to wrap them for postage.
Also, 4x114.3 25mm hubcentric wheel spacers (66.1mm Nissan centre bore) $80
Edited by sweefu
Hey i am having a "sh!t wont fit into my new garage sale.
96 180sx shell w/o hatch, SOLD
Engine, loom, ecu and box-$1600
Interior parts free on pick up
Side intercooler free on pick up
FMIC with sr piping $200 ono
Lhs front gaurd gone
Bonnet gone
Alot more crap for free or very cheap
94 seats - sold
If the shell isnt gone by the 25th its going to the ezy scrap but i would prefer it to go to the inport community
Pick up near war memorial.
All thats left is box and motor an FMIC
Edited by Dub-D
Apparently no1 wanted a cheap engine/no one could come up with money so vry big thanks to everyone that helped me move the heavy $"&$
I now have a spare yayai still hve the FMIC
Pm if interested
Edited by Dub-D
7kg/mm coilover springs, suit HSD HR, BC Racing etc $70
Hey guys anyone know of an SR20DET for an 180sx for sale ? need a red top cheers.
