GoSilvia
CA18DE and CA18DET Exhaust Camshafts
I have a S13 Silvia with a CA18DE. Due to a water replacement the half moon timing lug got broken in the exhaust camshaft.
I replaced the exhaust camshaft with an exhaust camshaft from a CA18DET motor.
The motor now has a nasty flat spot at 4000 rpm. The motor pulls a little sluggish up to 4000 rpm, hits the flat spot, once it gets past the flat spot it happily revs out to 7500 rpm with as much grunt as it used to.
My question is what is the difference between the NA and turbo exhaust camshaft? Is there a camshaft timing change needed?
The motor is running on the original CA18DE auto ECU, although the Silvia is now a manual.
Check your timing marks again. Easy to get it one tooth off.
As far as I can remember, DE and DET exhaust cams are very similar in spec. Same lift and duration, but initial timing is only different by about 5deg, which would be hardly noticable.
So you're saying a tooth out would be noticeable but 5 degress on the cam wouldn't be? You realise 5 degrees is about as much as 1 tooth?
I couldn't find the specs at the time, but you're probably right.
Mine was incorrectly setup one tooth out, and it was a dog.
