NISSAN FAST Thread (Thread Now Closed) - Hardtuned.net - Page 8
405 replies to this topic
#211 RB-20-SX
Posted 05 May 2011 - 01:21 AM
Could I get a part number for an extension housing seal for a RB71C#1 gearbox? (From a R32 RB20 manual) Ta muchly! Posted Image
My local dealerships are a tad lazy. Posted Image
#212 SIR ASHMAN
  • Car:CA18DET S13
Posted 05 May 2011 - 02:38 AM
32136-U0100
#213 RB-20-SX
Posted 05 May 2011 - 06:39 AM
thanks muchly, I know they'll be rare as, but mud guards / flaps for a 1990 180sx? someone pinched mine, havn't been able to find any for 3 years.
mud flaps like: This if at all possible.
#214 SIR ASHMAN
  • Car:CA18DET S13
Posted 05 May 2011 - 12:06 PM
There are 2 types available, one is listed under standard parts, the other is listed under optional accessories.
The optional ones have different part numbers for each vehicle paint code so they are pre painted (I need to know your paint code if you want these). The standard ones only have the one part number for all paint codes so I assume them to be black plastic or something plain like that.
Attached Image: standard.jpg
Attached Image: optional.jpg
So I'll need to know if you want standard or optional, front and rear (or just rear) and if you want optional I'll need you paint code.
#215 whyte
  • Car:ahh-34
Posted 09 May 2011 - 11:13 AM
hey mate, can i get part # for nissan R34 GTT 5 speed gearbox and R34 GT (non turbo) 5 speed gearbox.
#216 RB-20-SX
Posted 09 May 2011 - 12:28 PM
I believe i'm just after the standard rear codes thanks! Posted Image
#217 SIR ASHMAN
  • Car:CA18DET S13
Posted 09 May 2011 - 01:37 PM
RH - 78810-40F88
LH - 78811-40F88
#218 SIR ASHMAN
  • Car:CA18DET S13
Posted 09 May 2011 - 01:43 PM
GT looks to be 32010-AA100
GTT looks to be 32010-AA520
I say "looks to be" as am I not 100% certain, it doesn't specifically list GTT anywhere, but when you remove the part numbers for the 6spd, 4WD, and RB20 powered vehicles. There are only 2 part numbers left, one of them is marked GT, so logically the other would likely be GTT.
#219 wozza
Posted 10 May 2011 - 08:56 PM
Could you tell me the difference between turbo gasket kit 14401-69F28 and14401-69F27 ? Do they both fit a T28 ?
#220 SIR ASHMAN
  • Car:CA18DET S13
Posted 10 May 2011 - 10:17 PM
Neither of those part numbers show up in Parts Master (Nissan's reverse part number lookup program).
Also I do not ever recall seeing a gasket kit for the turbo, all the gaskets are sold separately and not in a kit.
It is possible though that those part numbers are newer than my almost 10 year old copy of FAST.
#221 wozza
Posted 10 May 2011 - 10:33 PM
Ok thanks. 14401-69F27 is a part nr Nissan gave me for the kit supposedly for a T28 but I've seen the ...F28 mentioned on google like here:
http://forum.s15oc.c...php/t-3755.html
might just have to take the chance with the ...F27.
#222 BASHO
  • Car:MX5
Posted 14 May 2011 - 07:17 AM
Is it possible to get the part No for a manual sunroof glass weather seal .
This is a rubber/plastic seal that goes around the edge of the sunroof glass and provides a weather seal between the sunroof glass and the car roof/body.
Any help would be much appreciated.
  • Model RPS13 JFTCW50 -- * CHASSIS -- RPS13 329373
  • Engine SR20DET 1998
  • Year 1997
  • Transmission (for driveline related parts)
  • HICAS/non-HICAS (for steering/braking/suspension parts)
  • ABS/Non-ABS (for steering/braking/suspension parts)
  • Paint code (for body panels)--326G
  • PLANT-------------------------X
    PLANTA
#223 SIR ASHMAN
  • Car:CA18DET S13
Posted 14 May 2011 - 05:09 PM
73872-01M05 - Protector-Glass
There are 2 things that look like seals, one goes around the glass and is called "Protector-Glass" the other goes around the sunroof hole in the body and is called 'Weatherstrip-Frame".
If you are after the part that goes around the glass then is will be the protector-glass.
#224 BASHO
  • Car:MX5
Posted 15 May 2011 - 05:31 AM
Thanks for that-protector glass it is--and $150.00 is the price I have been quoted by Nisssan Southport--ouchPosted Image .
#225 Spazo
  • Car:JDM S15
Posted 16 May 2011 - 01:08 PM
Could I get part numbers for:
(1999 Jdm S15 with sr20det)
vct unit
coilpacks
lifters
Thanks!
#226 SIR ASHMAN
  • Car:CA18DET S13
Posted 16 May 2011 - 01:44 PM
Just to make sure I've got the right numbers:
Attached Image: s15.jpg
That's the VTC unit and lifters in the diagram that your after right?
Sprocket Intake - 13025-65F00
Pivot-Rocker - 13234-52J01
Ignition Coil - 22448-91F00
#227 -LCD-
Posted 17 May 2011 - 03:30 PM
hey guys, need a part number...
im rebuilding some rx7 fc brakes (sumitomo calipers), which are essentially the same as the s14/s15 brakes. there a 4 bolts which hold the two halves of the calipers together, 14mm hex heads, M12 1.25 pitch?? x50mm threaded section, 50mm shank? these measurements are off the top of my head.
basically i need the part numbers (if available) for these bolts to see if they match the bolts in the fc calipers.
THESE ARE NOT THE BOLTS WHICH MOUNT THE CALIPERS TO THE KNUCKLE
THESE ARE NOT THE PINS THAT HOLD/ALIGN THE PADS
-dan
#228 SIR ASHMAN
  • Car:CA18DET S13
Posted 17 May 2011 - 05:12 PM
Since you seem to know exactly what you want here is the diagram for the S14/S15 front brakes.
The descriptions of the appropriate parts have been added to the diagram.
The numbers for "bolt-hex" and "washer-spring" shown in the diagram are the actual part numbers, all other number in the diagram are not part numbers and can not be used to order parts.
If you need part numbers for those other parts you will need to let me know, if you need the diagram for the rear brakes you will need to let me know.
#229 Jarno
  • Car:S13.4 SR20Det
Posted 17 May 2011 - 08:27 PM
Do you have the diagram of the R33 rear caliper ?
#230 SIR ASHMAN
  • Car:CA18DET S13
Posted 17 May 2011 - 08:41 PM
Which R33 specifically, there are multiple calipers. For RB25,RB26, 4WD, 4WS etc, and then some others that vary between years.
I'll need to know the year, the engine, and if it is 4WD or 4WS.
#231 Jarno
  • Car:S13.4 SR20Det
Posted 18 May 2011 - 05:55 AM
I wouldn't know they were sent to me for a 5stud conversion and there missing parts bit most likely off a rb25
#232 -LCD-
Posted 18 May 2011 - 10:16 AM
Thanks for the post, but the pin holds the pads in and the hex bolt Moira the caliper. It seems no one stocks the bolts that split the caliper. WTF
-dan
#233 SIR ASHMAN
  • Car:CA18DET S13
Posted 18 May 2011 - 01:06 PM
These are the 2 diagrams for the R33 RB25DET rear brakes:
Attached Image: r33.jpg
Attached Image: r332.jpg
Note: The numbers in the diagram are NOT part numbers and can not be used to order parts, you will need to tell me the numbers of the parts you require from the diagram and I will give you the part numbers for those parts.
#234 SIR ASHMAN
  • Car:CA18DET S13
Posted 18 May 2011 - 01:08 PM
-dan
The bolts themselves may not be sold separately, they may only come with the actual caliper assembly itself.
#235 -RPS13-
  • Car:5/97 RPS13
Posted 22 May 2011 - 07:38 PM
hi dude,
can i get a part number for S13 vehicle speed sensor??
any help appeciatted,
Cheers,
Jared
#236 SIR ASHMAN
  • Car:CA18DET S13
Posted 22 May 2011 - 08:19 PM
 -RPS13-, on 22 May 2011 - 07:38 PM, said:
hi dude,
Cheers,
Jared
25010-35F00
#237 -RPS13-
  • Car:5/97 RPS13
Posted 22 May 2011 - 08:24 PM
legend mate, thanks heaps.
Jared
#238 RB30DET
  • Car:1998 RB26/30 S14a
Posted 23 May 2011 - 11:00 AM
hey guys,
im after part numbers for the cam gear bolts for a RB26 also the there is a a square washer used on each gear need the part no for the washer
#239 RB30DET
Posted 23 May 2011 - 11:02 AM
i need part number for this and cam gear bolts
thanks in advance
  • Attached Image: DSC03979.JPG
#240 SIR ASHMAN
  • Car:CA18DET S13
Posted 23 May 2011 - 11:37 AM
 RB30DET, on 23 May 2011 - 11:00 AM, said:
hey guys,
Washer - 13030-D4200
Cam Gear Bolt - 13012-D4200
