Welcome to Hardtuned.net!
why not sign up as a member? It's free, and you get a tonne more features:
| Guest Message © 2010 DevFuse | |
clunky drive train please help !
#1
Posted 03 June 2009 - 12:20 AM
you could read on for references if your experiencing clunk's on your drive train and can't figure it out and you're replacing every thing!
#2
Posted 03 June 2009 - 09:33 AM
Big Boss, on Jun 2 2009, 11:20 PM, said:
mine is clunky as anything, it clunks sitting still putting it into gear lol.
so i plan on welding it, will this stop the clunky-ness aswell?.
if it doesn't i'll look at another diff
cheers
Contact Yo_stock on this forum man, think he has R180's coming out his a$$
#3
Posted 03 June 2009 - 11:24 PM
cheers
i'll see how i go, thanks mate!
#4
Posted 12 June 2009 - 11:27 AM
please, any body know???
#5
Posted 12 June 2009 - 01:09 PM
In saying that though it might not be so the only way you could tell is by welding it. R180s are cheap though so if your not happy and its still clunking get another one with less play or chuck thick oil in it lol or upgrade to a shimmed r200
Jay
#6
Posted 12 June 2009 - 01:55 PM
so will all diffs get play eventually? even the 2 way?
i'll weld mine and see what happens, then i'll look at upgrading to R200, do i need the half shafts aswell?
#7
Posted 12 June 2009 - 02:17 PM
Diffs will always have noises clunks chatter its just one of those parts.
Welding would be a good cheap option and if its still clunky just put thicker oil in.
With the R200 the diff will come complete with half shafts just gotta get the right diff - 6bolt(3x2) or a 5 bolt - 2 types, just a matter of replacing diffs on your car.
Shimming the R200 will make the lsd in the diff tighter so it will act like a locker when shimmed.
I have an R200 and I was usin penrite limslip 90 and didnt last longer than 3000km so I used limslip 140 lasted way longer, only downside is it feels a slight bit stiffer when moving for the first 500km or so.
Jay
#8
Posted 12 June 2009 - 02:29 PM
what is the best way to weld the diff? i'm going to do it with the bell housing still on and i'll clean it out with degreaser or brake cleaner, i was going to use a steel plate and weld it accross the spider gears
upgrading to R200 is a bit too expensive for me at the moment
then i will add truck oil!
haha
#9
Posted 12 June 2009 - 02:43 PM
#10
Posted 12 June 2009 - 03:44 PM
so when i pull the back plate off the diff i wll see holes that i need to fill?
i thought it would just expose the spider gears and i weld all 4 up with a plate to get better strength
hmm. it seems i am a little lost i should be able to see what you mean as i do it
#11
Posted 12 June 2009 - 04:33 PM
so welding the spider gears probably has nothing to do with the play on that part of the diff does it.
how can i fix it, i've got these engine moutns i want to put in but i cant yet because my diff is too violent.
#12
Posted 12 June 2009 - 08:46 PM
#13
Posted 14 June 2009 - 06:27 PM
#14
Posted 14 June 2009 - 09:58 PM
#15
Posted 15 June 2009 - 10:20 PM
i'll look for another diff, i got truck oil ready, penrite 140!
can i use an ark welder to do it?
#16
Posted 16 June 2009 - 11:04 AM
Noob question:
Hey mate, could you let us know the number on the bottle of that Penrite 140 or a picture even better.
I'm planning to shim my diff and a bit unsure which one is a "thicker" diff oil.
#17
Posted 16 June 2009 - 11:36 AM
full name is penrite competition diff oil SAE 140 extra heavy duty
it says, for LSD, older worn differentials, trucks and 4WD's
#18
Posted 16 June 2009 - 06:18 PM
I have a R180 sitting round the house if you need to buy it. It clunks slighty but thats cos I havent changed the oil in it.
found this for you man
http://zilvia.net/f/...l-approved.html
PM me if you want to buy the diff - Brisbane
and NRG180 I would reccomend usin the limslip 90 first and see how it goes
the higher the number(viscosity rating) the thicker the oil is - 0 thin 145 really thick
Jay
#19
Posted 19 June 2009 - 01:32 AM
2 questions remain though;
1. if the play of ones diff is in the spider gears, welding it should take the play out right?
2. can i use an ARK welder!?!?
#20
Posted 19 June 2009 - 03:34 PM
#21
Posted 19 June 2009 - 04:08 PM
if i need to rebuild my diff while it's out, if i weld it and its still clunky, where on earth can i get the bearings, or whatever i need to rebuild it, i would like to do this properly
i guess nissan?
#22
Posted 19 June 2009 - 04:19 PM
i don't have what this guy does, http://zilvia.net/f/...l-approved.html
he says, 2. Remove the 4 (17mm) bolts holding the Ring gear/ Axle assembly down.
but i don't have those bolts!
it just looks like this!
#23
Posted 19 June 2009 - 04:23 PM
As for what you said before about rebuilding it., there are so many good condition r180's kicking around, its a lot cheaper to go and buy one. Backlash is very rare in these diff's, and you should be able to pick up a good center for $50 or thereabouts
This post has been edited by Midnight_Garage: 19 June 2009 - 04:29 PM
#25
Posted 19 June 2009 - 04:48 PM
it wasn't that bad as an auto, but when i converted it the diff was so lashy!
yeah i just did what you said, i kind of post asking something, then answer myself 2 min later
lol.
#26
Posted 19 June 2009 - 06:09 PM
#27
Posted 19 June 2009 - 07:16 PM
so if the weld doesn't fix up the stupid lash what should i do from there? rebuild? or look for another diff? i know there's a R180, the exact same model as mine down the road with only 98XXX KM's on it
where as my diff has been an auto for 300XXX KM's and i converted it to manual, since then it's done 40XXX
#28
Posted 19 June 2009 - 07:47 PM
anyone want to sell me a good 180 center?
#29
Posted 19 June 2009 - 09:40 PM
#30
Posted 19 June 2009 - 11:12 PM
i also lost the little rubbers that come off the half shaft do i really need them, they're so insignificant.
so what is mini spooling j-spec?
oh and also, the bearings on the side of the centre of the diff they are pretty sloppy, but i don't think that's got anything to do with the whiplash?
could it?
thanks for the help guys
hopefully this clears things up for others also
Sign In
Register
Help
MultiQuote
