s14 sr20det solid head +built - Hardtuned.net
tomei ati je nismo
  • You cannot reply to this topic
No replies to this topic
#1 180athid
Posted 06 May 2017 - 09:55 PM
Engine
Nissan Sr20det (s14)
Full rebuild
Tomei 270 mm 12 mm lift cams
Tomei solid lifters
Tomei springs
Tomei rocker arm stoppers
Ported intake and exhaust ports
Je pistons
Manly rods
ATI harmonic balancer
Greddy larger engine sump
Greddy alloy engine pully
Nismo bearings
Nismo 1.4 mm head gasket
Nissan gasket kit
Nissan oil pump
Nissan timing chain
Arp head studs
Taark power steering pump relocation
Nismo thermostat
All machining and balancing done
cusco engine mounts (sit engine 10mm lower
Motor has done less than 1000 km
Was making 340rwkw on 22 psi e85 before I parted the car out
$5500 ono
  • Attached Image: 18274947_10158698683620241_4449856994927056847_n.jpg
  • Attached Image: 18222222_10158698683635241_8185424194918642496_n.jpg
  • Attached Image: 18268149_10158698683680241_1876790284914197249_n.jpg
