s14 sr20det into s13 body wiring - Hardtuned.net
6 replies to this topic
#1 youngclipz13
Posted 17 March 2017 - 08:56 PM
so i was thinking about buying a s13 with a knocking sr20det non vvt, as i already have a s14 sr20det vvt motor complete with uncut loom and ecu and gearbox, was just wondering if the s14 motor loom will plug straight into the s13 body loom if not, what does it require to get the motor going with the car ?
#2 (Locky)
  • Car:kouki s14
Posted 18 March 2017 - 02:23 AM
About 5 wires to get it running
Then all the wires in the dash conector for your gauges/ consult port
Or buy an expensive conversion loom for a more plug and play solution
#3 youngclipz13
Posted 18 March 2017 - 06:00 AM
have done a little research all i can pick up was the 5 wires that you mention needed to be run in is for the vvt ? and the dash conectorc can i just use diagram for the pin outs for the s14 loom and match them to the s13 pin out or will i need to cut the conector and rejoin them ?
#4 (Locky)
  • Car:kouki s14
Posted 20 March 2017 - 11:55 AM
no thats people using a s14 engine on s13 lom and ecu.. they just dodge up the VCT. to convert the loom the s13 joins the body loom near the headlights where as s14 under the dash. Need to extend 2 wires to reach ( to do with ECU power) start signal, bridge fuel pump relay or extend that wire ect
the conectrots are completly different for under dash connector (J4?) so need to either chop one off a s13 engine loom or cut and join each wire some wires are same soe differnt
#5 Protius
  • Car:S14 200SX
Posted 21 March 2017 - 05:57 AM
If you want an easy plug in option shoot me a message at http://www.facebook.com/whiteyswiring Send me both looms you have and i can send you back a loom that will plug in and work without hassles.
Edited by Protius, 21 March 2017 - 05:57 AM.
#6 pur40m
Posted 21 March 2017 - 04:45 PM
How much do you roughly charge for this if i send you both the s13 sr20de engine loom and s14 sr20det engine loom to modify it to go in a s13 sr20de chassis
Thanks
#7 Protius
  • Car:S14 200SX
Posted 21 March 2017 - 05:50 PM
Shoot me a message via the page and we can discuss pricing. Very affordable in my opinion.
